VROOM Posted 3 hours ago Share Posted 3 hours ago Hello, Audi A5 2007 3 litre diesel May it be noted the car drove from auction to unit about 5 miles no issues. I have an issue with a car just purchased at auction so don’t know the history of the car. One of the issues is fuel tank malfunction display. After some research I replaced the fuel sender unit under back seat. At first the car started fine (without moving). Once I completed all my works as it needed new brakes and springs etc the car was ready to go a drive. I barely made it out the unit and the car kept cutting out not wanting to start. Code was low fuel pressure. When turning the ignition on I couldn’t hear the sender activating so I checked the fuses. Sure enough the third fuse down in middle row for the fuel pump had blown. This was replaced but still the car will not start. I have tried putting the ignition on several times to bleed the system but still no joy. When I use Easy Start the car will turn over for a second then just cut out. It’s not firing up for some reason. Am I missing something? Thanks for any help Quote Link to comment Share on other sites More sharing options...
Magnet Posted 2 hours ago Share Posted 2 hours ago Welcome Ryan, When you say you replaced the fuel sender unit, are you meaning the in-tank fuel pump? If so, new ( what brand?) or secondhand? Quote Link to comment Share on other sites More sharing options...
