Brian McG Posted 3 hours ago Share Posted 3 hours ago Hi I have a 2023 A6 Avant. I find i need to top up the oil every 5000km. Is this normal? Quote Link to comment Share on other sites More sharing options...
Magnet Posted 2 hours ago Share Posted 2 hours ago Welcome Brian, How much oil are you adding every 5000kms? What mileage has the car done to date? Have you owned it from new, and has it always used the same quantity of oil? Kind regards, Gareth. p.s. Where is Ork? 1 Quote Link to comment Share on other sites More sharing options...
Brian McG Posted 2 hours ago Author Share Posted 2 hours ago Hi Gareth There's 30K km on the clock. I top up a litre each time. I bought the car when it was a year old. Cork is what I meant to put in the location box. I'll fix that. Regards Brian Quote Link to comment Share on other sites More sharing options...
Magnet Posted 1 hour ago Share Posted 1 hour ago Many thanks for coming back on this Brian. Apologies for translating to miles, so members on here can get a better understanding. 30K Kms. equates to around 19K miles, and in my book, this car should be thoroughly ‘run in’ by now, and its oil consumption should have settled to a lower extent than what it is - currently around 1,500 miles/ pint. We take it the oil you are topping up with is the correct grade and specification, and if so, I would be doing possibly 2 things:- Check in your handbook what the oil consumption rate should be. Request your dealer to conduct an oil consumption test on the car. Has the car had a service yet? If not, then it should be due. Perhaps you could let us know how you get on Brian. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Brian McG Posted 1 hour ago Author Share Posted 1 hour ago Thanks Gareth I'll do that and get back ro you. Regards Brian Quote Link to comment Share on other sites More sharing options...
