liviuc8 Posted 2 hours ago Share Posted 2 hours ago Hi all. I recently changed all the pads and wear sensor but the light is still on. From what I understood it might be the wiring loom. If so, how dificult is it to change? Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted 1 hour ago Share Posted 1 hour ago 15 minutes ago, liviuc8 said: Hi all. I recently changed all the pads and wear sensor but the light is still on. From what I understood it might be the wiring loom. If so, how dificult is it to change? Hi what brand of wear sensor did you use as a lot of the cheaper ones I have fitted have been like this because the little spring bit on the end where it fits to the pad is missing, if its not there thats what conducts the current so the light stays on. Steve. 1 Quote Link to comment Share on other sites More sharing options...
liviuc8 Posted 1 hour ago Author Share Posted 1 hour ago Hi Steve. I used ATE. I thought that's what Audi uses as OEM part 1 Quote Link to comment Share on other sites More sharing options...
