WonkyDonkey1971 Posted 2 hours ago Share Posted 2 hours ago Hey folks. Have had the car about 18 months, 110,000 miles. Have had intermittent no crank for last few months. Sometimes starts 1st time other times it's 10+ cycling of the key. No codes. I note that when it's not going to crank the radio and lights aren't interrupted. Is it likely to be ignition switch or should I be looking somewhere else in the electrical system (or somewhere else altogether). Any thoughts would be welcome as I don't fancy writing a blank cheque to someone to trace an intermittent fault if I can help it! Quote Link to comment Share on other sites More sharing options...
Steve Q Posted 11 minutes ago Share Posted 11 minutes ago Do you get any tickets when turning the key, ie starter motor trying to start it? Could it be crank position sensors? Cam sensors? Or an imobiliser issue? Quote Link to comment Share on other sites More sharing options...
