alfred Posted October 9, 2024 Posted October 9, 2024 Hello Alfred here i have replaced everything between the clutch pedal and clutch, and it still dosent want to engage to first gear. what could be the problem, we have tried to ventilate the system and it dosent work. what to do?? Audi a3 8p 1.6 2005
Stevey Y Posted October 9, 2024 Posted October 9, 2024 On 10/9/2024 at 3:57 PM, alfred said: Hello Alfred here i have replaced everything between the clutch pedal and clutch, and it still dosent want to engage to first gear. what could be the problem, we have tried to ventilate the system and it dosent work. what to do?? Audi a3 8p 1.6 2005 Expand Hi have you checked the linkage on the gearbox as they sometimes fail and its difficult to select first gear, how did you try to ventilate the slave cylinder, have you got a good clutch pedal?. Steve.
alfred Posted October 10, 2024 Author Posted October 10, 2024 we did try to ventilate the slave cylinder, and the clutch pedal is good and the linkage did we also change. Alfred
