Anzie7 Posted October 9 Posted October 9 Hi, I have the above car, engine number CZZA. The car broke down suddenly and wouldn't start, diagnosed fault to being 2 injectors. Replaced all 6 just to be sure. When the car was fired up it wasn't sounding great. Turns out compression lost on 4 cylinders and there could be damage to the bottom end (potentially bent conrods). The quotes to repair have been quite high, and obviously an engine replacement is also pricey. Does anyone know if there is another Audi/VW bottom end that would be a straight swap with no hassle? I have the chance of a Touareg engine code CRCA, but been advised it won't work. Appreciate any help in advance. Thanks.
cliffcoggin Posted October 10 Posted October 10 19 hours ago, Anzie7 said: When the car was fired up it wasn't sounding great. Turns out compression lost on 4 cylinders and there could be damage to the bottom end (potentially bent conrods). Did the cambelt break? If it did you could also need a top end because of damaged valves.
Anzie7 Posted October 11 Author Posted October 11 On 10/10/2024 at 6:15 PM, cliffcoggin said: Did the cambelt break? If it did you could also need a top end because of damaged valves. No, it didn't.
