DC64 Posted 4 hours ago Share Posted 4 hours ago A6 C7 4G 2014 When driving in a straight line, car pulls consistently to the right. On acceleration the car will pull to the right. When driving over uneven surfaces the car will jerk the steering in either direction. Issue is more noticeable at low speed but still present at higher speeds. Slight delay or notch (loose not tight) when turn from one direction to the other. No play in tie rods and all bushings are tight after multiple checks Even tyre thread. No bent alloys. Lower rear control arm + ball joint replaced on left and right Drop links replaced left + right Steering tracked Any ideas as to what the cause is - I am stumped. Initial Final Front Camber Left -1 -0.54 Right -0.54 -1 Toe Left 1.15 0.09 Right -1.06 0.09 Total 0.09 0.18 Rear Camber Left -1.42 -1.42 Right -1.18 -1.18 Toe Left 0.18 0.18 Right 0.18 0.18 Total 0.36 0.36 Max Thrust Angle 0 0 Quote Link to comment Share on other sites More sharing options...
Steve Q Posted 1 hour ago Share Posted 1 hour ago Have you had a diagnostic check to see if any fault codes flag up regarding the steering rack? Quote Link to comment Share on other sites More sharing options...
DC7HSE Posted 1 hour ago Share Posted 1 hour ago 43 minutes ago, Steve Q said: Have you had a diagnostic check to see if any fault codes flag up regarding the steering rack? Hi Steve, this is my car the OP created the thread on my behalf. I have scanned the car multiple times using OBDII on 2 different scanners. There may have been one related to steering 12 months ago, prior to the current issuse, which I cleared and has not returned. I am considering buying VCDS just to see if it throws up anything. You suspect steering rack? Quote Link to comment Share on other sites More sharing options...
DC7HSE Posted 44 minutes ago Share Posted 44 minutes ago 22 minutes ago, DC7HSE said: Hi Steve, this is my car the OP created the thread on my behalf. I have scanned the car multiple times using OBDII on 2 different scanners. There may have been one related to steering 12 months ago, prior to the current issuse, which I cleared and has not returned. I am considering buying VCDS just to see if it throws up anything. You suspect steering rack? The fault that I cleared was Steering Column Electronics Systems 00895 CCS/ADR Control Unit thanks Quote Link to comment Share on other sites More sharing options...
