kotu Posted October 19, 2024 Posted October 19, 2024 I recently pulled the fuses from 1. Driver assistance system controller 2. Crossroad assistant, driver assistance systems 3. Surround camera The cause was the 360 surrounding camera jamming (I wanted to put the controller to sleep for a moment) and I guess I messed up. Now almost all driver assistance systems are inactive. Audi adaptive light: fault! High beam assistant: fault! Audi pre sense: currently limited. There were a lot of errors. The ones I can't delete are: 00A5- Front sensors of driver assistance systems 65537 C12D8F Crossroad assistant HMI status feedback unreliable CAN bus, fault 0009- Central electronic system 67735 U112300 Data bus, received fault value (00001001 Active 0009 Central electronic system 67737 U112300 Data bus, received fault value (00001001 Active Before this, maybe 5 times I had these systems not working, but after waiting 10 minutes and restarting the car, everything worked. Now it still doesn't work. I think the j1121 controller is damaged How can I check this?? I have an ODIS diagnostic cable.
Steve Q Posted October 19, 2024 Posted October 19, 2024 It might need a more sophisticated diagnostic tool from a dealer.
