Adam92 Posted yesterday at 05:47 AM Share Posted yesterday at 05:47 AM (edited) Hi All, How do you go about changing xenon headlight bulbs on A8 2010? it looks @ first glance pretty sealed around headlights… is it a headlight out job? All help would be appreciated… Thanks adam Edited yesterday at 05:47 AM by Adam92 Quote Link to comment Share on other sites More sharing options...
Solution Steve Q Posted yesterday at 08:30 AM Solution Share Posted yesterday at 08:30 AM This is how you change it: 2.5 Renewing bulb for dipped beam head‐ lights Removing – Switch off ignition and take out ignition key. – Turn light switch to position “0”. – Remove appropriate front wheel. – Remove relevant front wheel housing liner ⇒ Rep. gr. 66 . – Loosen locking bolt -1- a few turns. – Release retaining tabs -arrows- and detach housing cover for dipped beam headlights from headlight housing. Audi A8 2003 ➤ Electrical system - Edition 08.2014 132 Rep. gr.94 - Lights, bulbs, switches - exterior But you can take the bumper off and headlight out if you wish. Pictures for reference to show what it looks like behind the wig and bumper etc. 1 1 Quote Link to comment Share on other sites More sharing options...
Hammie1982 Posted 21 hours ago Share Posted 21 hours ago they are an absolute pain in the bum to change. but going in thru the wheel well is the quickest and "easiest" Make sure you have a axel stands and not working under there with the car held up by the jack. I use wheel blocks and axel stands every time now after a near miss some years ago that seen a shogun fall off a jack and narrowly miss taking a friends arm off at the shoulder. 2 1 Quote Link to comment Share on other sites More sharing options...
