RussF99 Posted 2 hours ago Share Posted 2 hours ago Hi, I have a 2022 A3 plug in hybrid. I have been charging with the provided cable to a 3 pin plug in the uk but the cable is now not working. Has anyone else had this issue and what did you do about it? Interested to know whether you leave it out because it only has an IP55 rating. Thanks. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted 1 hour ago Share Posted 1 hour ago Ha e you managed to confirm it's the cable and not a fault with the car? Quote Link to comment Share on other sites More sharing options...
Magnet Posted 52 minutes ago Share Posted 52 minutes ago Not wanting to highjack the thread, but have you checked the fuse in the plug - plugs and fuses used for these obviously take an abnormally high current? If fuse tests OK, then test for continuity from the 3 pin plug end of the lead to the plug that plugs into the car. If you don’t have a test meter, or are uncertain about how to use it, it’s much safer to nip the cable around to an electrician to test it for you. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted 48 minutes ago Share Posted 48 minutes ago Gareth does raise a good point and to add, have you checked the plug socket in/on the house that you use? Quote Link to comment Share on other sites More sharing options...
