a4b9beauty Posted October 23 Share Posted October 23 Hi All, just looking out for recommendations for brake pads and discs... any particular brands I should get or avoid... I've got a4 b9 2017 2.0 quattro Thanks for your help in advance Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 24 Share Posted October 24 What is your driving style Rit? Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
a4b9beauty Posted October 24 Author Share Posted October 24 I drive on the motorway frequently. I would say border line impatient sometimes when stuck in traffic. I've not had a set of brakes for around 3 years, if that helps. Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 24 Share Posted October 24 Thanks Rit, Motorway miles will be easy on brake pad wear, and unless you are ‘last seconds on the brakes’ then standard pads should do you fine. In case it helps, I’ve been using Brembo of late on family cars to good effect. Same with discs if needed. I buy mine via. eBay at competitive prices from reputable suppliers. You could try Parts in Motion for example. If you want something a bit more ‘performancy’ then you could choose from the EBC product range. Please let us know how you get on. Kind regards, Gareth. 1 Quote Link to comment Share on other sites More sharing options...
a4b9beauty Posted October 24 Author Share Posted October 24 Ok i will check them out, I am last seconds on the brakes a lot specially when traffic builds up on the motorway journey in peak traffic. I'll check those brakes out. Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 24 Share Posted October 24 So you are heavy on the brakes then! Quote Link to comment Share on other sites More sharing options...
Magnet Posted 17 hours ago Share Posted 17 hours ago Any progress Rit? Quote Link to comment Share on other sites More sharing options...
