Elson Posted October 29, 2024 Posted October 29, 2024 (edited) hello, I have a problem with my Audi car 1.6 diesel 2010, it happens when the car is cold, at first when I turn it on, it turns off after 5 seconds, then when I turn it on again, it doesn't turn off. it's also consuming oil, I've only done 6000km and it took out the oil lamp. any idea what it could be? maybe it's a turbo? Edited October 29, 2024 by Elson
Steve Q Posted October 29, 2024 Posted October 29, 2024 I'd recommend a diagnostic check to see if any fault codes flag up. Could be more than one issue. Could be a glow plug issue, injector, cam position sensor etc.
Elson Posted October 30, 2024 Author Posted October 30, 2024 Thanks for the feedback, I’ve made a diagnostic check and the only thing that appears to me is the auxiliary water pump, but sometimes it also emits white smoke, maybe it could be the injectors
Elson Posted October 30, 2024 Author Posted October 30, 2024 (edited) test Edited October 30, 2024 by Elson
Steve Q Posted October 30, 2024 Posted October 30, 2024 Could be. Could be an issue with the turbo. And it's leaking oil into the turbo. It can cause engine to run away. Look ar it on YouTube
cliffcoggin Posted October 30, 2024 Posted October 30, 2024 3 hours ago, Elson said: I’ve made a diagnostic check Was that a professional diagnosis or one you did yourself with a cheap code reader?
