Ferg Sail Posted October 30, 2024 Posted October 30, 2024 Hey crew, My Audi S3 is triggering its low oil pressure light. The dipestick level is fine. There are no funny noises and the car isn't overheating. is this just a case of a faulty sensor or is it something bigger. I am planning to check the pressure later in the week but was seeking advice if anyone has encountered this aswell, kind regards, Ferg
Ferg Sail Posted October 30, 2024 Author Posted October 30, 2024 * it also triggers at random. I can do a pull and it won't trigger and then when I drive normally it will trigger for 3 seconds and will then go away.
Steve Q Posted October 30, 2024 Posted October 30, 2024 Definitely could be the sensor. This would be picked up on a diagnostic check to see if any fault codes flag up. 1
Ferg Sail Posted October 30, 2024 Author Posted October 30, 2024 Ran a diagnostic. Nothing came up apart from my car running a bit lean but this will be fixed when I get a tune.
Stevey Y Posted October 30, 2024 Posted October 30, 2024 2 minutes ago, Ferg Sail said: Ran a diagnostic. Nothing came up apart from my car running a bit lean but this will be fixed when I get a tune. Hi find the pressure sensor and change it, probably about £20 for the part at least that will rule that option out. Steve.
Ferg Sail Posted October 30, 2024 Author Posted October 30, 2024 Will do, am going to pick one up after work.
Solution Ferg Sail Posted October 31, 2024 Author Solution Posted October 31, 2024 Put new a new oil pressure sensor in last night which seems to have fixed the problem. I also noticed my intake wasn't sitting properly on the turbo and was loose. Re-fitted everything and now I have no codes and the car isn't running lean anymore. thanks everyone for your help! 2
