johnymingle Posted November 5, 2024 Posted November 5, 2024 My lights left on, indicator left on, and seatbelt chime has stopped working, and I've walked away a few times and left the left or right lights on, by leaving my indicator stalk down or up. I cant find anything g on you tube!! Just hoping someone can give me a bit guidance as to where to look and fix it
Stevey Y Posted November 5, 2024 Posted November 5, 2024 58 minutes ago, johnymingle said: My lights left on, indicator left on, and seatbelt chime has stopped working, and I've walked away a few times and left the left or right lights on, by leaving my indicator stalk down or up. I cant find anything g on you tube!! Just hoping someone can give me a bit guidance as to where to look and fix it Hi best start would be to get the car scanned for faults then work forward from there. Steve.
johnymingle Posted November 5, 2024 Author Posted November 5, 2024 Yes I did that steve, but my scanner doesn't go so indepth. Im not prepared to throw big bucks at it......I would like to know where the chime is for starters!! Thanks.
Steve Q Posted November 6, 2024 Posted November 6, 2024 There's a picture of the buzzer in the back of the cluster here: http://www.audi-sport.net/vb/a4-a4-cabriolet-s4-forum-b6-chassis/84577-buzzer.html
cliffcoggin Posted November 6, 2024 Posted November 6, 2024 13 hours ago, johnymingle said: .I would like to know where the chime is for starters!! What's the point? Unless you solve the root cause of the problem it is likely to keep throwing up other faults and error messages. 1
johnymingle Posted November 6, 2024 Author Posted November 6, 2024 5 hours ago, Steve Q said: There's a picture of the buzzer in the back of the cluster here: http://www.audi-sport.net/vb/a4-a4-cabriolet-s4-forum-b6-chassis/84577-buzzer.html Cheers but I don't see anything just an advert!!
johnymingle Posted November 6, 2024 Author Posted November 6, 2024 40 minutes ago, cliffcoggin said: What's the point? Unless you solve the root cause of the problem it is likely to keep throwing up other faults and error messages. I can test it
Hammie1982 Posted November 6, 2024 Posted November 6, 2024 The Buzzer itself is part of the cluster. if its the buzzer then its (unless you are a master craftsman with it comes to soldering) a replacement cluster thats needed. Completely cost prohibitive in my opinion. As for testing for errors, yes you can throw VCDS on the car, but i dont remember ever getting an error on the computer for this problem (ive had 2 different cars that suffered with the same thing... an A4 and an A3). What i might suggest before you go ripping into the dash to look at the rear of the cluster, is checking other connections around the dash. particularly around the light switch or the indicator stalk. 1
johnymingle Posted November 6, 2024 Author Posted November 6, 2024 50 minutes ago, Hammie1982 said: The Buzzer itself is part of the cluster. if its the buzzer then its (unless you are a master craftsman with it comes to soldering) a replacement cluster thats needed. Completely cost prohibitive in my opinion. As for testing for errors, yes you can throw VCDS on the car, but i dont remember ever getting an error on the computer for this problem (ive had 2 different cars that suffered with the same thing... an A4 and an A3). What i might suggest before you go ripping into the dash to look at the rear of the cluster, is checking other connections around the dash. particularly around the light switch or the indicator stalk. Ok thanks
