Guest Posted November 8, 2024 Posted November 8, 2024 Hello 馃憢馃徎聽 I have an issue that happens at random. There鈥檚 a static popping/thud sound from the sub and speakers. Anything can trigger this, such as operating a window or the lights coming on, and even steering the wheel. Sometimes it can be a little crack, and others it鈥檚 a big thud from the sub.聽 this has only started when a new stereo was installed. I鈥檝e disconnected any wires that aren鈥檛 relevant for operation. A simple yet expensive option is to change the unit, but I want to avoid that and see if anyone has experienced this before, and maybe solved it.聽 聽 thanks!
cliffcoggin Posted November 8, 2024 Posted November 8, 2024 Have you checked for the most obvious cause: a loose wire or connection shorting out?
Guest Posted November 8, 2024 Posted November 8, 2024 One of the first things, yeah. But nothing happened when I moved things about.聽
Guest Posted November 9, 2024 Posted November 9, 2024 No I don鈥檛 think so. I just connected the iso lead. And fed a live wire from the fuse box.聽 how would I be able to identify an earth problem? Could be a good place to start.聽
cliffcoggin Posted November 9, 2024 Posted November 9, 2024 The extent of my electrical testing knowledge is to wriggle all the connections. Beyond that I can not help. Perhaps one of the wires you discarded as irrelevent is actually relevent after all.
Guest Posted November 9, 2024 Posted November 9, 2024 It鈥檚 certainly worth another try. Could just be a problem with the stereo itself. Thanks for your help.聽
