Odhran Posted November 11, 2024 Posted November 11, 2024 (edited) Hey, Just wondering does anyone know what the fix might be for this? I have Semi Dynamic indicators on my 8V PFL but the far right indicator stays on at all times. Could it be a relay problem and that’s why it’s stuck on or does it need coding? Edited November 11, 2024 by Odhran
Odhran Posted November 11, 2024 Author Posted November 11, 2024 Left hand side is normal.Right indicator is the stuck on at all times.
Stevey Y Posted November 11, 2024 Posted November 11, 2024 1 hour ago, Odhran said: Left hand side is normal.Right indicator is the stuck on at all times. Hi are the light units aftermarket or as factory in which case it could be an earthing fault on that side. Steve.
Odhran Posted November 11, 2024 Author Posted November 11, 2024 1 hour ago, Stevey Y said: Hi are the light units aftermarket or as factory in which case it could be an earthing fault on that side. Steve. Thanks Steve. I think they’re factory with a relay system connected( I’ll include a picture of what I think it has). I haven’t taken them apart yet so I’m not sure if they are aftermarket. I bought the car and it had this feature and assumed it was just coded like this.
Stevey Y Posted November 12, 2024 Posted November 12, 2024 21 hours ago, Odhran said: Thanks Steve. I think they’re factory with a relay system connected( I’ll include a picture of what I think it has). I haven’t taken them apart yet so I’m not sure if they are aftermarket. I bought the car and it had this feature and assumed it was just coded like this. Hi in those wiring cables are a can bus system that enables the light to flash without throwing a fault, try the connections first and if the cables are genuine they will have VAG/Audi stamped on them. Steve.
