Ryan1988 Posted November 18, 2024 Posted November 18, 2024 Does anybody know the best/ brightest reverse lights as need them to light up as much as possible where I park the car thanks in advance
cliffcoggin Posted November 18, 2024 Posted November 18, 2024 I have a feeling that the power and brightness of all car lights is subject to the Construction and Use regulations, so it would be worth checking before modifying your car. 1
Ryan1988 Posted November 18, 2024 Author Posted November 18, 2024 Thank you don't really want to change the car from factory just the brightness of the bulbs thank you for replying
cliffcoggin Posted November 18, 2024 Posted November 18, 2024 In that case try renewing the bolbs, because they degrade slowly over time. Are the lenses clean on the inside? Are the reflectors dull or dirty? 1
Ryan1988 Posted November 18, 2024 Author Posted November 18, 2024 I will order the same bulbs and try them thank you. Yes I've been inside to see if I could put LEDs in dosent look like I can I've gave it a good clean on the inside and out Thank you
Steve Q Posted November 18, 2024 Posted November 18, 2024 For LEDs you'll need specific ones that won't throw up a bulb out warning on the dash. Your alternative option is to fit an accessory light. 1
Ryan1988 Posted November 18, 2024 Author Posted November 18, 2024 Right ok I'll have a search for the ones what you have said thank you
Ryan1988 Posted November 19, 2024 Author Posted November 19, 2024 Got some led ones that said warning/error free for make and model didn't work so just got the normal bulbs thank for all replys and help appreciated it 1
