robertson Posted November 19, 2024 Posted November 19, 2024 Hi can some body help my temp guage has started to go from 90 back to 60 and back up to 90 all the time when driving any idea Please.
Steve Q Posted November 19, 2024 Posted November 19, 2024 This could be caused by a failing thermostat 2
cliffcoggin Posted November 19, 2024 Posted November 19, 2024 It could also be a faulty temperature sender. 1
Magnet Posted November 21, 2024 Posted November 21, 2024 Thanks David, I would replace only one of the two mentioned parts at one time, and test, otherwise you won’t know which one was the culprit. Think sender is the easiest of the two, so I would be trying that first. Let us know how you get on David. Kind regards, Gareth.
Magnet Posted December 9, 2024 Posted December 9, 2024 Hello David, Would you be kind enough to up date us on this, so others can benefit from your experience. Many thanks and kind regards, Gareth.
robertson Posted December 11, 2024 Author Posted December 11, 2024 Hi it seems to be the sender unit havent changed yet will let you know when i have thanks 1
