Redmole Posted November 20, 2024 Posted November 20, 2024 Since I have owned the car and after a full nights charge it used to do the 34 miles range over the past 2 days this has dropped to 19 miles. I use the audi charger is this a charger problem or a battery one the car is 21 plate
Magnet Posted November 20, 2024 Posted November 20, 2024 Welcome Brian, I would think this is more to do with the cold weather effect on the battery’s efficiency. Kind regards, Gareth.
Steve Q Posted November 20, 2024 Posted November 20, 2024 Definitely most likely the weather. But feel free to get a diagnostic check or battery test for peace of mind.
cliffcoggin Posted November 20, 2024 Posted November 20, 2024 Undoubtedly the cold weather. Not only do low temperatures reduce the battery range, they also slow down the charging. Are you sure the battery is at 100%, or whatever level you normally charge to, when you set off in the morning?
Redmole Posted November 22, 2024 Author Posted November 22, 2024 Thanks for info we have noted different ranges
