Camerond20 Posted November 23, 2024 Posted November 23, 2024 Hi guys, For the last couple of days I’ve been turning the heating on in the car but they just don’t seem to warm up at all. The fans are running perfectly fine, they just don’t heat up. After looking online, the main cause I saw was a blown head gasket, although I’ve checked the other symptoms of a blown head gasket and I think I can rule that out (luckily!). My engine gets up to temp within around 5 mins and will stay at temp without rising/decreasing. My oil isn’t milky, my coolant is not being overused so I’m unsure what the cause is. Any help would be greatly appreciated! Thanks guys 😊
Steve Q Posted November 23, 2024 Posted November 23, 2024 Issue with the heater matrix is one option or issue with heater controls. 1
Camerond20 Posted November 23, 2024 Author Posted November 23, 2024 24 minutes ago, Steve Q said: Issue with the heater matrix is one option or issue with heater controls. Right, Thankyou! It’s a massive relief from originally thinking it was a blown head gasket 😂
Steve Q Posted November 23, 2024 Posted November 23, 2024 3 minutes ago, Camerond20 said: Right, Thankyou! It’s a massive relief from originally thinking it was a blown head gasket 😂 Excessive white smoke out the exhaust would be a sign of that plus if it was loosing coolant. 1
Camerond20 Posted November 23, 2024 Author Posted November 23, 2024 23 minutes ago, Steve Q said: Excessive white smoke out the exhaust would be a sign of that plus if it was loosing coolant. Neither of them are happening thankfully! I’ve checked the pipes that go into the cabin and one of them is very hot and the other is like warm at best, so could that be a blockage within the pipe potentially?
Steve Q Posted November 23, 2024 Posted November 23, 2024 I'd get the garage to check but I'd suspect an issue with the heater matrix.
Camerond20 Posted November 23, 2024 Author Posted November 23, 2024 Just now, Steve Q said: I'd get the garage to check but I'd suspect an issue with the heater matrix. Booked in for the end of next week, so hopefully I can get it sorted before it gets any colder outside! Horrible timing 😂 thank you pal!
Magnet Posted November 24, 2024 Posted November 24, 2024 Hello Cameron, There is no shortage of nonsense available on the internet, and perhaps a shortage of logical thought. As Steve says, if coolant is holding temperature. Kind regards, Gareth.
enc Posted November 30, 2024 Posted November 30, 2024 On 11/23/2024 at 5:02 PM, Camerond20 said: Hi guys, For the last couple of days I’ve been turning the heating on in the car but they just don’t seem to warm up at all. The fans are running perfectly fine, they just don’t heat up. After looking online, the main cause I saw was a blown head gasket, although I’ve checked the other symptoms of a blown head gasket and I think I can rule that out (luckily!). My engine gets up to temp within around 5 mins and will stay at temp without rising/decreasing. My oil isn’t milky, my coolant is not being overused so I’m unsure what the cause is. Any help would be greatly appreciated! Thanks guys 😊 Hi, on first viewing my 1.4 tfsi, I noticed the same issue you are experiencing… no warm air from blowers. Turned out to be the heater matrix. From new, Audi fit some kind gel bag in the system which over time breaks down and clogs up the matrix. Mine was sorted before purchase but I believe it’s quite an involved job.
