mikesmerc Posted 20 hours ago Posted 20 hours ago Hi all, new here desperately seeking help. My wife arrived home this evening after a push start from the train station. All lights illuminate on the dash when ignition is on, go to crank and nothing happens, not even a click or a light dimming. Checked the battery voltage and its approx 12.8V. I've been googling this for hours looking for locations relays and fuses. Are there any on this model related to my non cranking issue? I attached a pic of the under bonnet relay fuse/relay box. Thanks for reading , any help would be appreciated greatly Mike
Magnet Posted 20 hours ago Posted 20 hours ago Welcome Michael, Sorry to hear of your issue. Regrettably, I cannot see how anyone can isolate the actual problem without access to the car. Probably pretty obvious but it could be anything from battery or any connection there on, ignition switch , wiring, relay, starter motor solenoid or motor itself. As I see it would be best left to a trusted local auto electrician to source the problem for you, unless you are equipped with suitable test equipment and the experience to use it. Apologies. Kind regards, Gareth.
cliffcoggin Posted 8 hours ago Posted 8 hours ago Michael. While the problem may be any of those that Gareth listed, there is also a good chance that the battery may be at fault if it is more than say six years old. The 12.8 volt reading tells you nothing about the internal condition of the battery so I advise you to get it tested professionally. The reason is that the car's electronic systems are sensitive to seemingly trivial power variations.
