HI , I am new to this forum and hoping someone out there who can advise me.
Problem, - none of the internal lights work, add to that the main instrument display dulls down when the engine starts , otherwise it is bright as does the MMI display.
I have checked all the fuses with a DVM and they are all ok . I have an elm327 device and i ran carscanner app on my cell phone , it doesn't pick up any DTC fault codes, I did a reset to see what that would do if anything and the lights flashed on and then off.  Just wondering if anyone has had experience of this and can advise.
Fairly recent about 7 months ago , but as it was just lighting I tried to look into it more. Recently I was loaned an elm327 unit and downloaded carscanner app. I could not see any fault codes but worked put yesterday if I do a reset of the ecu the lights flash on and then go off, all of the interior ones that is. So yo me that says , fuses , lights cables must be OK. But not sure why this only happens when is the ecu that's reset.rest of car seems to be OK.all external lights are good.
There is a chance that the instrument cluster is faulty. It's a common problem on A3s, which can be repaired for less than £300.
If you want to be certain of the diagnosis you are going to need a better diagnostic tool than that. The usual recommendations are for OBD11 or VCDS I think they are called. Stevey Y will be able to confirm if he reads this.
