squre1970 Posted December 7 Posted December 7 Hi All, the passenger rear door does not lock with remote or with the internal locking switch on the drivers door. The electric window works and the red door light works. I have changed the door module as well but no joy. it was working fine 2 weeks ago and then just suddenly stopped. i cannot see any broken wires in the door joint either and continuity test say the wires are fine. any help will be appreciated.
cliffcoggin Posted December 7 Posted December 7 Can we assume you have tested the fuse? Have you checked the mechanical parts of the door lock to ensure they are not jammed?
Sid2020 Posted Sunday at 10:17 PM Posted Sunday at 10:17 PM Central locking solenoid is built into the lock mechanism and is a common failing , if it’s not totally failed you might hear a slight rumbling from it but won’t have the power to engage the lock.
