Mihai242622 Posted December 7, 2024 Posted December 7, 2024 Hi I have a 2007 a6 c6, and I have problems with the rear lights. I will tell you the whole problem so you can understand. 2 months ago I tried to put my taillights on led, but they didn't work. All I did was disconnect the old taillights and put the new ones on, but they didn't work and I put the old ones back on(before doing that all lights worked). As soon as I put them on, it started to appear on my dashboard and my signaling and brake did not work. I cleaned it thinking it was not making contact and it worked until about a month ago, and suddenly it started not working again. I didn't want to disassemble again, so I ordered a holder and installed it, but in vain. The turn signal was working, but the light on the left brake still didn't work. I bought another light computer, installed it and it went to the left, but it no longer went to the right. Then I bought entire tail light thinking that I would solve the problem, but it didn't work either. Now it doesn't work either on the right or on the left. What do you recommend to do? If anyone has experienced the same, please help me. Thank you!
Stevey Y Posted December 8, 2024 Posted December 8, 2024 22 hours ago, Mihai242622 said: Hi I have a 2007 a6 c6, and I have problems with the rear lights. I will tell you the whole problem so you can understand. 2 months ago I tried to put my taillights on led, but they didn't work. All I did was disconnect the old taillights and put the new ones on, but they didn't work and I put the old ones back on(before doing that all lights worked). As soon as I put them on, it started to appear on my dashboard and my signaling and brake did not work. I cleaned it thinking it was not making contact and it worked until about a month ago, and suddenly it started not working again. I didn't want to disassemble again, so I ordered a holder and installed it, but in vain. The turn signal was working, but the light on the left brake still didn't work. I bought another light computer, installed it and it went to the left, but it no longer went to the right. Then I bought entire tail light thinking that I would solve the problem, but it didn't work either. Now it doesn't work either on the right or on the left. What do you recommend to do? If anyone has experienced the same, please help me. Thank you! Hi you said you tried to put your lights to LED did the new units have a Canbus link if not its probably caused an embedded fault in the lighting control module, would suggest scanning the car and deleting any light related faults. Steve.
