DanHemingway Posted December 14, 2024 Posted December 14, 2024 Hi, as the title says I’m getting a Left dipped / main beam error, I thought it’d be just as simple as changing the bulb but obviously it’s not and the wheel and lining has to be removed. When I type my reg in I don’t get the same bulb replacement that’s already in the car, I think it sees my car as an 8P with it being A 2012 but it is an 8V. The left light is flickering on off, it might stay on for a few miles then goes off. Would this just be a bulb replacement or I’ve seen some saying ballast? Also does anyone know what type of bulb I need? Thanks
cliffcoggin Posted December 14, 2024 Posted December 14, 2024 It sounds like a loose connection. Check the plug connection and bolb contacts for looseness. Clean them with contact cleaner as well.
Stevey Y Posted December 14, 2024 Posted December 14, 2024 2 hours ago, DanHemingway said: Hi, as the title says I’m getting a Left dipped / main beam error, I thought it’d be just as simple as changing the bulb but obviously it’s not and the wheel and lining has to be removed. When I type my reg in I don’t get the same bulb replacement that’s already in the car, I think it sees my car as an 8P with it being A 2012 but it is an 8V. The left light is flickering on off, it might stay on for a few miles then goes off. Would this just be a bulb replacement or I’ve seen some saying ballast? Also does anyone know what type of bulb I need? Thanks Hi if you post a picture of your headlight that will help as if you have projector lenses my guess is that it will be a D3s bulb which will possibly need ballast unit as well, both are easy swaps. Steve.
DanHemingway Posted December 14, 2024 Author Posted December 14, 2024 Hi, it’s these headlights, I think it is the bulb as just checking and the light it a pink shade where as the other is white.
Stevey Y Posted December 15, 2024 Posted December 15, 2024 23 hours ago, DanHemingway said: Hi, it’s these headlights, I think it is the bulb as just checking and the light it a pink shade where as the other is white. Hi thats the bulb then probably wont need a ballast, I am pretty sure these are D3s bulbs, a word to the wise change both sides, the standard bulbs are 42000 kelvin so for a little treat go up to 5500 kelvin and have much better lights. Steve.
