Tony3.0BKNQuattro Posted December 18, 2024 Posted December 18, 2024 would the wiring on my 2006 BKN engine be compatable to the CGK engine?
Solution Steve Q Posted December 18, 2024 Solution Posted December 18, 2024 My advice would be to take the wiring harness, ECU, injection pump and maybe instrument cluster from the donor car. As the imobiliser is linked to the ECU, cluster and pump. You could risk it and hope its compatible and/or get an auto electrician to wire up the harness. Also I've hidden your other thread as it's a duplicate. 1
