Scallytoes Posted December 19, 2024 Posted December 19, 2024 Hi, apologies for the length but want to be detailed. I have a 2014 2.0tdi at 94k and am experiencing white smoke from the exhaust when the car is up to temp (after approx 5 mins of driving) I’m loosing coolant, topping up prob every 7-10 days) No hesitation starting, no distinct loss of power, no engine mgt lights on. No mayo in the oil filler cap and no visible leaks that I can see anyway. I booked it in with my mechanic and he stated there was nothing that points to a head gasket issue and had a chat with a vag friend who said it could be an issue with the inlet manifold, egr and or egr cooler but that would be a process of elimination after the car is dismantled kind of thing. any clues yet?? I went online (like you do) and someone mentioned to check a fuse in the battery fuse compartment. Couldn’t see anything blown on the small removable fuses. On my way back in after a short drive my fan kicked in (this used to happen all the time and after-run but haven’t heard this for some time coming to think of it) anyway, shortly after my particulate filter light appeared. Normally I’d just take it out on the motorway to clear this but feel less inclined to do so while the car is poorly) No lights on the dash before the dpf light, no limp mode, no hesitation on startup or acceleration, no smoke on startup, no mayo in oil cap at a bit of a loss. Really really hoping someone very clever recognises the above and says ‘I know exactly what this’ and hope that’s not just wishful thinking. over to you guys….my 160k miles 8P seemed like a tank compared this 8V Thank you so much for reading this far and racking your brains over this, eternally grateful 🙏 1
Steve Q Posted December 19, 2024 Posted December 19, 2024 I'd definitely consider the egr/egr cooler as the main cause with this. But you could get a pressure test done on the engine to be safe. 1
Scallytoes Posted December 19, 2024 Author Posted December 19, 2024 My mechanic did say he’d pressure test it so assume he’s done that to rule out the head gasket option. Looking at the symptoms you seem bang on the money, just hoping that solves the issue. Really appreciate and value your opinion and time so thank you will keep this thread alive and update for others too, now to price one up and get a price for fitting.
Scallytoes Posted December 20, 2024 Author Posted December 20, 2024 The other thing is… I’ve seen egr deletes and software remaps mentioned as an option rather than put a new egr / egr cooler on a car that’s already at 95k miles now??
Steve Q Posted December 20, 2024 Posted December 20, 2024 7 hours ago, Scallytoes said: My mechanic did say he’d pressure test it so assume he’s done that to rule out the head gasket option. Looking at the symptoms you seem bang on the money, just hoping that solves the issue. Really appreciate and value your opinion and time so thank you will keep this thread alive and update for others too, now to price one up and get a price for fitting. You're welcome, please keep us posted on how you get on 🙂 Yes that's an option, but we're seeing more and more cars coming here with further issues after having dpf or egr deletes. 2
moghm Posted March 4 Posted March 4 Hi. So just bought an Audi A3 1.4 tfsi 2014. I am surprised at the amount to smoke/vapour thats being emitted. Bit scary. Coolant is just above min. its like a ploom of vapour that is emiited when I get to the top of the gear change and when I change to next gear (manual), then its gone, its not like its leaving a trail behind me in the way a diesel car would do, it swirls around the back of the car. Drove on motorway for 15 minutes and got off on A/B roads. Nothing then, clear. I am going to take it to a mechanic for piece of mind. Car has 64k, clean MOT through its life, cant see any leaks, oil is clear, has full service history, no warning lights, nothing an a cheap obd2, pulls well, MPG is good, etc. Any ideas ? Many thanks
Scallytoes Posted March 4 Author Posted March 4 I’m in the process of sorting my a3 out, similar symptoms. Posted myself on here and I think another forum and kind people with more knowledge have advised, kind of confirmed it’s a problematic egr valve that’s leaking into the manifold and then being burnt. Mines not too problematic atm and had other priorities recently but looking to get it sorted soon. I noticed when it did need topping up with coolant the more I filled the worse it got so top it up to min level now. Planning on keeping the car so don’t mind spending even though it’s done 96k miles atm. Sounds like we’re in the same boat and many others out there, common issue with them apparently
Scallytoes Posted March 4 Author Posted March 4 Sometimes mid-diagnosed as head gasket failure, not saying it’s not (I’m no mechanic) but sounds familiar
moghm Posted March 4 Posted March 4 10 minutes ago, Scallytoes said: I’m in the process of sorting my a3 out, similar symptoms. Posted myself on here and I think another forum and kind people with more knowledge have advised, kind of confirmed it’s a problematic egr valve that’s leaking into the manifold and then being burnt. Mines not too problematic atm and had other priorities recently but looking to get it sorted soon. I noticed when it did need topping up with coolant the more I filled the worse it got so top it up to min level now. Planning on keeping the car so don’t mind spending even though it’s done 96k miles atm. Sounds like we’re in the same boat and many others out there, common issue with them apparently What is the Estimate for an EGR replacement (parts and labour), is this the same as an EGR cooler ? This problem is better than a head gasket right ? Many thanks
Scallytoes Posted March 4 Author Posted March 4 Yeah same thing as far as I’m aware, apparently needs to come out but hard to get to as it’s right at the back and kind of hidden (would be wouldn’t it) so more about the labour charges. Mines on a 2014 plate too but a 2.0tdi. Apparently if you can get someone to bypass it that will confirm that’s the offending part. I was quoted around the 700 mark (not sure how competitive that is) have you just bought it? garage or private? Anyone please correct me on anything here as I’m kinda muddling through this issue too
moghm Posted March 4 Posted March 4 1 minute ago, Scallytoes said: Yeah same thing as far as I’m aware, apparently needs to come out but hard to get to as it’s right at the back and kind of hidden (would be wouldn’t it) so more about the labour charges. Mines on a 2014 plate too but a 2.0tdi. Apparently if you can get someone to bypass it that will confirm that’s the offending part. I was quoted around the 700 mark (not sure how competitive that is) have you just bought it? garage or private? Anyone please correct me on anything here as I’m kinda muddling through this issue too Private. Always owned bms before this, not passing any judgement. A bit gutted
Scallytoes Posted March 4 Author Posted March 4 Yeah it’s a bit naughty that, they had to have known to be honest. If you’re mechanically minded might be a diy job but looking at a couple of YouTube videos it’s beyond my skill set even though Ive just replaced a front rad and cooler for a friend.
moghm Posted March 4 Posted March 4 Car booked in for Monday, could have done without this but thats how it goes
Scallytoes Posted March 4 Author Posted March 4 Let us know how you get on please. Would be interested to know how what they say.
cliffcoggin Posted March 26 Posted March 26 On 3/5/2025 at 12:07 AM, moghm said: Will do Well M. We are waiting with baited breath for the promised update. Will you oblige?
enc Posted March 27 Posted March 27 On 3/4/2025 at 1:21 PM, moghm said: Hi. So just bought an Audi A3 1.4 tfsi 2014. I am surprised at the amount to smoke/vapour thats being emitted. Bit scary. Coolant is just above min. its like a ploom of vapour that is emiited when I get to the top of the gear change and when I change to next gear (manual), then its gone, its not like its leaving a trail behind me in the way a diesel car would do, it swirls around the back of the car. Drove on motorway for 15 minutes and got off on A/B roads. Nothing then, clear. I am going to take it to a mechanic for piece of mind. Car has 64k, clean MOT through its life, cant see any leaks, oil is clear, has full service history, no warning lights, nothing an a cheap obd2, pulls well, MPG is good, etc. Any ideas ? Many thanks I have 2012, 1.4 tfsi, in cold, damp wether, it too emits an alarming amount of vapour but only idle, No odour, no coolant loss. I was concerned the first winter this occurred but it cleared once warmer temperatures arrived. Same through this last winter but now we are experiencing above 15 degrees vapour has cleared. No loss of coolant with mine. I remember doing a google search when I first experienced it … seems to be pretty common. 1
Kev-P Posted March 27 Posted March 27 42 minutes ago, enc said: I have 2012, 1.4 tfsi, in cold, damp wether, it too emits an alarming amount of vapour but only idle, No odour, no coolant loss. I was concerned the first winter this occurred but it cleared once warmer temperatures arrived. Same through this last winter but now we are experiencing above 15 degrees vapour has cleared. No loss of coolant with mine. I remember doing a google search when I first experienced it … seems to be pretty common. Its very common, in any car. Its usually condensation built up in the exhaust which turns into steam as the car warms up. It will usually disappear after a while when its all evaporated.
enc Posted March 27 Posted March 27 19 minutes ago, Kev-P said: Its very common, in any car. Its usually condensation built up in the exhaust which turns into steam as the car warms up. It will usually disappear after a while when its all evaporated. Of course! But in all my years of car ownership I’ve never experienced it to the extent of this little 1.4 tfsi 🤔😂
moghm Posted March 27 Posted March 27 (edited) On 3/26/2025 at 3:49 PM, cliffcoggin said: Well M. We are waiting with baited breath for the promised update. Will you oblige? Apologies for the delay in replying, i have no excuse, life admin on high,etc 🙂. So as I drove the car more and if, lets say the temp was above 12 degrees, no issue really. Yes the vapour is present on cold days, I do think it is vapour now and once car is warm there is nothing even when booting. I paid £96 for a thorough health check and the following was found. Battery weak, front bushes slightly worn and the most peculiar thing no codes after a deep scan which mechanic said was unsual. No issues with car at the moment, its running pretty well. I am just going to let it run. Is there anything when ur car is warm, i think its a VW/Audi peculiarity re: vapour. However, I have seen Hyundais do it also. Edited March 27 by moghm
moghm Posted March 27 Posted March 27 7 hours ago, enc said: I have 2012, 1.4 tfsi, in cold, damp wether, it too emits an alarming amount of vapour but only idle, No odour, no coolant loss. I was concerned the first winter this occurred but it cleared once warmer temperatures arrived. Same through this last winter but now we are experiencing above 15 degrees vapour has cleared. No loss of coolant with mine. I remember doing a google search when I first experienced it … seems to be pretty common. I concur
Scallytoes Posted March 27 Author Posted March 27 Genuinely glad it’s not bad news for you. Hope your foray to Audi from BMW stays this way too!
cliffcoggin Posted March 27 Posted March 27 Thanks M. Steam or water vapour is inevitable because water is one of the combustion products of any engine burning a hydrocarbon. It will be even more pronounced from a hydrogen fuelled engine if such things come to pass.
moghm Posted March 27 Posted March 27 47 minutes ago, Scallytoes said: Genuinely glad it’s not bad news for you. Hope your foray to Audi from BMW stays this way too! Im afraid ill be reverting back to BMW once my divorce is settled. I do like some of the features on the Audi. Good car 🙂
