image.thumb.png.41f1723ca049f33a06eadf6b69c011f6.pngMy car won鈥檛 start put my little tester on and this is what it said I haven鈥檛 a clue it鈥檚 Christmas Eve Eve and I need my car so no garages open any help or advice would be really appreciated thanks聽
The could be caused by a faulty injector, high pressure fuel pump, fuel pressure regulator or purge valve.聽
Is the car misfiring?聽
Have you cleared the fault and tried to start it?聽
No it鈥檚 not misfiring but the heater plug sign was flashing it wouldn鈥檛 clear thanks
No probs at all. I'd definitely look at the items I've described. Ideally a more advanced scanner might show so e more codes.聽
When you cleared the code could you drive normally? Or did it come back?聽
It just came back and wouldn鈥檛 start but the day before the power wasn鈥檛 there it was like in limp mode the garage I use isn鈥檛 open till after the new year I鈥檒l just have to wait but thanks for the help it鈥檚 given me something to think about thanks聽
