Dear all thanks for adding me. I changed the drivers side window module today as the old one had fell to pieces. However I don’t have any power going to the new module. Oddly enough the electric mirrors also don’t work. All my fuses are ok as I have checked them all and all the power control module fuses too. Any other areas that I should check?
when the lights go on should the panel not illuminate?
the passenger side operates normally.
Welcome Calum.
Worth checking for broken wires in the flexible harness section between A post and door, before getting into anything else.
Hi magnet yes I think I will look at this next see if there are any broken wires in here. Cheers
Hello Calum,
I wouldn’t think about it, but just do it. Perhaps you can let us know how you get on.
