Martyboy Posted December 30, 2024 Posted December 30, 2024 Good evening, just after some advice please. My daughter has recently bought a Audi A1 1.6 tdi 2012. it has developed a noise when the car is under load. I have attached a video of myself with the car in gear and my foot on the brakes. As you can hear when I lift the clutch and the engine loads the noise begins. thanks in advance Marty聽 聽 聽 IMG_3195.mov
cliffcoggin Posted December 31, 2024 Posted December 31, 2024 Sorry Martin, I will not download anything from an untrusted source. If you would care to put it on Youtube for example I will be happy to watch it.
Steve Q Posted December 31, 2024 Posted December 31, 2024 If it's bought within the last 30 days from a dealer get it back to them asap for them to fix. They have a duty to fix it free of charge.聽
Martyboy Posted December 31, 2024 Author Posted December 31, 2024 Hi Steve it was a private sale around 3 months ago.聽 聽 聽 聽 聽
Steve Q Posted December 31, 2024 Posted December 31, 2024 I wonder if an engine mount, or gearbox mount has failed causing either to knock on the body.聽
Martyboy Posted December 31, 2024 Author Posted December 31, 2024 48 minutes ago, Steve Q said: I wonder if an engine mount, or gearbox mount has failed causing either to knock on the body.聽 Not a bad shout I will investigate thank you聽
Steve Q Posted December 31, 2024 Posted December 31, 2024 37 minutes ago, Martyboy said: Not a bad shout I will investigate thank you聽 You're welcome, please keep us posted on how you get on聽 1
cliffcoggin Posted December 31, 2024 Posted December 31, 2024 2 hours ago, Steve Q said: I wonder if an engine mount, or gearbox mount has failed causing either to knock on the body.聽 Agreed. It doesn't sound tinny enough to be an exhaust knock. 1
Martyboy Posted March 25 Author Posted March 25 Good morning , update and advice please. The A1 finally broke down in February. Had the injectors tested and three failed. Note it had four injectors new in 2022 and only done about 10k before they have failed. 馃槥 anyway to test the car we have fitted four used injectors out of a scrap car. My question is without the information to code the injectors in to the A1 how long will it last before a light or fault code appears ? As there are no numbers on the injectors.聽 聽 cheers聽
spartacus 68 Posted March 25 Posted March 25 3 hours ago, Martyboy said: Good morning , update and advice please. The A1 finally broke down in February. Had the injectors tested and three failed. Note it had four injectors new in 2022 and only done about 10k before they have failed. 馃槥 anyway to test the car we have fitted four used injectors out of a scrap car. My question is without the information to code the injectors in to the A1 how long will it last before a light or fault code appears ? As there are no numbers on the injectors.聽 聽 cheers聽 What was the knocking noise? Seems unusual for 3 injectors to fail. How long will they last? Million dollar question. The engine needs the information for long term fuel management, otherwise its Russian roulette before they potentially fail again. Did you fit new stretch bolts and washers?
