CerberusA3 Posted December 31, 2024 Posted December 31, 2024 Have been getting this fault code for a little over 3 weeks, the car started by going into limp mode while doing motorway speeds (120km/h) you could turn it off and back on and it would fix it self. Then it started to do it on nation road speeds (100km/h) turning off an on again was a solution but was guaranteed to fix the fault, yesterday the car went into limp mode doing 30km/h and now is completely dead on power, I have changed the MAF sensor and no improvement, I’m told the code relates to a Turbo actuator fault but just checking if anyone else has had a similar issue before i pursue fixing the turbo. Thanks 🙂
Steve Q Posted December 31, 2024 Posted December 31, 2024 I'd definitely say it's a turbo issue. Don't buy cheap Chinese turbos as they'll probs last just out of warranty. Go for a good quality one. 1
Sid2020 Posted January 1 Posted January 1 I work on lots of different manufacturers so can’t say for sure about your exact model but the diverter valve is a common failing and usually the diaphragm inside it that fails and they throw fault codes typically to do with low boost or map/mad out of correlation, worth removing and doing a visual inspection 1
CerberusA3 Posted January 3 Author Posted January 3 On 1/1/2025 at 4:14 PM, Sid2020 said: I work on lots of different manufacturers so can’t say for sure about your exact model but the diverter valve is a common failing and usually the diaphragm inside it that fails and they throw fault codes typically to do with low boost or map/mad out of correlation, worth removing and doing a visual inspection Checked the diaphragm in the turbo actuator and it was holding vacuum, i ran a turbo wastegate test and it only worked 2/10 times so possible the rod in the turbo actuator is broken? she's booked into Audi for a diagnosis next week (i know they'll tell me i need a new everything) i'll post once i know more 😀
CerberusA3 Posted January 3 Author Posted January 3 1 hour ago, Sid2020 said: Map/Maf just read my error Well i've changed both now so atleast i know it's not them
CerberusA3 Posted January 3 Author Posted January 3 On 12/31/2024 at 6:04 PM, Steve Q said: I'd definitely say it's a turbo issue. Don't buy cheap Chinese turbos as they'll probs last just out of warranty. Go for a good quality one. definitely agree, the cheaper you go the more problems your going to create for yourself
Sid2020 Posted January 3 Posted January 3 Have you removed and inspected the diverter valve as different to a turbo actuator
CerberusA3 Posted January 3 Author Posted January 3 2 hours ago, Sid2020 said: Have you removed and inspected the diverter valve as different to a turbo actuator i was under the impression Diesels don't have diverter valves, could be wrong
