Dipstick tube on A6 C8 Avant
Go to solution Solved by Stevey Y,
Hi all,
new(ish) Audi owner here. I wanted to do an oil change on my A6 Avant 2.0 TDi 40 and understand there *may* be a dipstick tube hidden in there somewhere with a bung sealing it closed. I have an EWK oil extractor & don’t fancy jacking the car and taking out all those screws. Does anyone know where the tube is, I’’ve had a look & saw the US petrol ones have this? Any help appreciated, photos would be better. Thanks in advance
  • Solution
3 hours ago, Darko said:
Hi all,
Hi pull the engine cover off and the tube is about half way down on the right you can't miss it as it has a loop fitting on the top, to remove it twist and pull.
Ya wee dancer.  I can’t believe you solved that one so fast. I spent longer than I care to admit looking for it with a torch. Much higher up and more accessible than I assumed. Well done, thanks
I marked it as solved, not the same or better?
No, Dave not the same ( or better). Just think about it - what you have said is that it has been ‘Solved’ , but you’re not attributing that solution to Steve’s experience and kind response, so please just mark his solution post as ‘Liked’ - it is what should automatically follow and shows your appreciation.
Didn’t think we would need to ask, but….
Thank you.
