Andy_B Posted January 9 Posted January 9 Hi all. I have a 2019 S3 that is giving me an ignition light funky disco聽 from time to time. The ignituon lights stay on or flicker even with the engine running. Sometimes the dash goes blank and gives me "Ignition powered off" or similar and, according to my better half to whom it has just happened, the heater fan goes off. It will start and drive as normal and has occurred while driving. I don't know if its related but each time I start the car the rear occupancy/outside temp display, which are at the same location on the dash, flicker between the two displays. I have had the car since September and its happened 3 times including today. Any suggestions welcome. Thanks Andy
cliffcoggin Posted January 9 Posted January 9 The prime candidate to my mind is a dying battery. The recent cold weather is revealing the weaknesses of all batteries. If it is the original five year old battery I would not hesitate to change it; if it is more recent I suggest you get it professionally tested before buying a new one. Make sure you get any new battery coded to the car. 2
Andy_B Posted January 9 Author Posted January 9 (edited) Ok thanks. It's not something I would have considered as it starts on the button. I have a decent tester so I'll give it a try. Edited January 9 by Andy_B
cliffcoggin Posted January 10 Posted January 10 The ability of a battery to crank the engine is not proof that it is in good condition.
Telsown Posted January 10 Posted January 10 I concur Clifford, Having recently purchased a new battery I did have some teething problems which I later found out was to do with the battery not being fully charged. With hindsight I should not have assumed a new battery would be fully charged, quite the opposite in fact and perhaps good practise is to fully charge a new battery no matter what! I do recommend the CTEK MXS 10. Although pricey, I feel its about the best for any battery that you would ever own. Terry
Andy_B Posted January 13 Author Posted January 13 Ok, here's battery test results Battery is date coded 06/23. Temperature was zero degrees. The car had covered a 25 mile journey at 10.30pm the previous evening and the test was at about 10am. 2nd pic is test before starting 3rd is test with engine running (I think 馃) 4th and fifth self explanatory. No idea if this tells anyone anything but happy to consider any suggestions. Car will be left until Thursday evening and I will repeat the test. Andy
cliffcoggin Posted January 19 Posted January 19 What were the results of the retest Andy? Please transcribe to text as reflections in your photos make them difficult to read.
Andy_B Posted January 19 Author Posted January 19 Battery test from this evening after being left for four days. 16% charge looks rubbish but it started on the button.
Andy_B Posted January 19 Author Posted January 19 (edited) I thought I'd posted the updated test. Hadn't pressed send!!馃榿 Edited January 19 by Andy_B Typo
cliffcoggin Posted January 19 Posted January 19 16% looks rubbish because it is rubbish, and needs to be replaced. As I said on Jabuary 10th "The ability of a battery to crank the engine is not proof that it is in good condition."
Andy_B Posted January 19 Author Posted January 19 I'm a old school "if the battery is knackered the car won't crank" type of guy, but every day is a learning day 馃槃 I am ordering one tomorrow. Just got the VCDS diagnostic kit so will be attempting the coding too.
cliffcoggin Posted January 20 Posted January 20 13 hours ago, Andy_B said: I'm a old school "if the battery is knackered the car won't crank" type of guy, I was too until the car suffered simultaneous聽 unexplained electrical problems that all magically disappeared on fitting and coding a new battery. It was a hard lesson to learn. I know of two other threads on the forum in which the owners refuse to accept their batteries are defective because a meter reading says it still has 12 volts. As the old adage goes "you can lead a horse to water but you can't make it drink." 1
Solution Andy_B Posted January 29 Author Solution Posted January 29 So, my horse has drunk the water and I've fitted a new battery聽. All good so far but saying that I haven't had disco ignition lights for the week prior.聽 I'll update in a month or so, hopefully it's been put to bed. Andy 1
Andy_B Posted January 29 Author Posted January 29 I replaced like for like Bosch S5 A08. I just changed serial number in VCDS to include the date I swapped it. 1
cliffcoggin Posted Thursday at 05:49 PM Posted Thursday at 05:49 PM Good news Andy, and thanks for letting us know.
