Darkprophecy Posted January 11 Posted January 11 Hi guys, all not a sudden turbo is not working. There's no smoke or anything but the spooling isn't happening and there is a loss of power. There was a vacuum pipe on back of engine near the top which has come off before causing the same issue but I've checked the pipes and all seem fine. When I remove that specific pipe it pisses for a second so there's vacuum there. I did not on the turbo actuator or wategate? Has some oil on it but does seem to move ok when I apply force by hand. Any ideas or advice welcome, I miss the whistle and wind down when I turn car off and of course the 170 plus bhp hehe
Stevey Y Posted January 11 Posted January 11 27 minutes ago, Darkprophecy said: Hi guys, all not a sudden turbo is not working. There's no smoke or anything but the spooling isn't happening and there is a loss of power. There was a vacuum pipe on back of engine near the top which has come off before causing the same issue but I've checked the pipes and all seem fine. When I remove that specific pipe it pisses for a second so there's vacuum there. I did not on the turbo actuator or wategate? Has some oil on it but does seem to move ok when I apply force by hand. Any ideas or advice welcome, I miss the whistle and wind down when I turn car off and of course the 170 plus bhp hehe Hi miss the whistle, thats normally a sign of a worn Turbo or a split boost hose, you should not hear anything on a variable vane Turbo its not like a fixed vane unit. Steve. Steve.
Darkprophecy Posted January 12 Author Posted January 12 Thanks for the reply mate. Ya probably right but it's still not working...hope nit isn't the turbo being dead but surely if that was the case I'd have some serious smoking issues?
Stevey Y Posted January 13 Posted January 13 17 hours ago, Darkprophecy said: Thanks for the reply mate. Ya probably right but it's still not working...hope nit isn't the turbo being dead but surely if that was the case I'd have some serious smoking issues? Hi, only get smoke when the bearings are shot, your problem may well be either sticky vanes or the vane control on top of the turbo is shot, if its vacuum controlled it may be the diaphragm in the unit if it electrically controlled its normally the control box thats fried, do you have any codes? Steve. 1
Darkprophecy Posted January 17 Author Posted January 17 Hi there, I can't seem to fit my obd2 reader to the car, seems socket is slightly different.. There's no mil light but I know that doesn't mean codes are not in the system. I'm sure I can hear a small vac leak but can't find where it is. Gonna check the actuator solenoids with brake bleed vac pump see if I can find something.. wish I had a diagram of the system so I could tick off bits.
Darkprophecy Posted January 21 Author Posted January 21 I've ordered an adapter to plug laptop in, I'm researching software to take a look at any codes. I see vcds is mentioned alot, might give that a download and see what it's about. Hopefully it's like bmw's Ista d and the like. As for type of actuator it's this one in picture.. also where does those pipes and solenoid mount? My brother must have had issues at some point but can't see anywhere obvious and flapping about isn't good lol
Stevey Y Posted January 22 Posted January 22 20 hours ago, Darkprophecy said: I've ordered an adapter to plug laptop in, I'm researching software to take a look at any codes. I see vcds is mentioned alot, might give that a download and see what it's about. Hopefully it's like bmw's Ista d and the like. As for type of actuator it's this one in picture.. also where does those pipes and solenoid mount? My brother must have had issues at some point but can't see anywhere obvious and flapping about isn't good lol Hi thats the boost solenoid its vacuum controlled and sits on the exhaust side of the turbo to control the vanes opening and closing, cheap good diagnostic is OBDEleven. Steve.
Darkprophecy Posted February 1 Author Posted February 1 Just replaced boost solenoid, made no difference 😕 if I stick a vacuum pump on the actuator it does move freely but I hear a small hiss down the back near turbo somewhere. Not sure what that could be and I'm stuck for ideas now.
Fly Fisher Posted 4 hours ago Posted 4 hours ago Hi, I have had the same problems in the recent past. Took the car to my local garage to replace the turbo. Cost a bit but problem solved. I don't mind working on my classic car, but this new fangled stuff is beyond me I,'m afraid
