20241222_122330.thumb.jpg.ef5e2df72a0db33a48e7858bf7d1e9c9.jpgHi, just looking for advice on changing the fuel lines in the picture. Is it as simple as removing and replacing or will the system need bleeding. Also I measured the plastic pipe as 5.7 with not very accurate caliper. Anyone know the size I'm guessing 5.6. Thanks for any help.
Mark.
If that is the return line, not the delivery line, then it will not need to be bled.
The outside diameter is unimportant; it's the internal diameter that needs to match your existing hose to ensure a snug fit on the metal pipe.
Ensure the hose is suited to the fuel. Not all grades of hose can be used on both diesel and petrol.
