Stuart Hindle Posted January 15 Posted January 15 I've a broken spring and cannot find replacements. I'm told the part number is 4F0 511 115 CM I cannot find thi anywhere. I am told that sline is 30 mm lower than standard which is what I was told about the le,man's height. If I can use a different spring how on earth do I exactly which one. I've tried numerous companies for the origonal spring and told no chance. I'm off the road at the moment its a nightmare. On a lighter note, the weather is loads better so, cycling it is : ) Oh, Happy New Year : )
Steve Q Posted January 15 Posted January 15 I could have e sworn they both have the same ride height.
cliffcoggin Posted January 15 Posted January 15 Whatever spring you settle on, ensure you do the same on the other side. Springs should always be replaced with matched pairs.
