Mooogie Posted January 20 Posted January 20 The joy.. every time I start up, I get a warning ding and message that there is a malfunction with the rear spoiler. I don't think it is related to my alternator about to fail (again) since my OBD11 is showing 14.8v charge to battery (when engine running, so this looks fine). Audi USA have a TSB (https://static.nhtsa.gov/odi/tsbs/2022/MC-10209108-0001.pdf) that the spoiler motor brushes don't have enough pressure and are replacing under warranty up to 50k miles. No such info seems to be available in the UK.. plus I'm well outside my warranty now. OBD11 seems to suggest the spoiler stop switch see below? Anyone had this issue, know where the switch is and if replacing it cures the problem? Thanks! my OBD scan gives this.. Car: Audi Year: 2019 Body type: Sportback Engine: DLZA kW ( hp) l Mileage: 104420 km --------------------------------------------------------------- 46 Comfort System System description: BCM2 MLBevo Software number: 4N0907064AD Software version: 0128 Hardware number: 4N0907064D Hardware version: H14 Faults: B134329 - Rear spoiler stop switch Implausible signal static Priority - 5 Malfunction frequency counter - 1 Unlearning counter - 220 km-Mileage - 104420 km Dynamic environmental data - 3A3E2E5A2EB42E4517501B015A100460000000000077008E001D01010A00003D00001755FFFFFFFF date - 2025-01-20 17:13:32
NJP10 Posted January 21 Posted January 21 Mine only does it on the motorway only, whilst it’s up when you slow down it bleeps with the rear spoiler fault. Then it stays up until you park up and shut the car off completely and only then you have to press the button to drop it down, it won’t go down automatically. 1
Mooogie Posted yesterday at 10:13 PM Author Posted yesterday at 10:13 PM (edited) Well, 2 months later and it has decided to just start working again... without me doing a thing! With the manual control to put it up, I've greased the hinges and pivots, so wondering if it had somewhat seized for a while, and then unstuck itself... Edited yesterday at 10:14 PM by Mooogie 1
