Good morning, last year I put on a aftermarket throttle body on , ever since then the engine light has been on , it does not effect the drive whatsoever, unfortunately it won’t pass the not , I have purchased a reader and it comes up with p2109 thoroughly attached, any help would be appreciated.IMG_2955.thumb.jpeg.ab186a759788ae86fb1dd72cd442c4fe.jpeg
It might need coded to the car believe it or not
Calling @Sid2020  (don't mean to harass you, but your knowledge of this is far beyond my own and you're pretty active here)
Found a wire out of the plug that plugs into the throttle body housing , sorted , many thanks
Glad you got it sorted, open circuit faults  often mean you’ve dropped a feed wire but finding where on the circuit can be a challenge.
