Pan Posted January 23 Posted January 23 (edited) Hi Gents, First post! Hello to all. In the middle of changing heater core and draining coolant. Can anyone tell where this drain location is? Engine is a 2.0 TDI 190PS CNHA Workshop manual isn't very clear. Thanks, Brian Edited January 23 by Pan engine model details
Solution Pan Posted January 23 Author Solution Posted January 23 Scrolling through the manual I found this, states it is the aux pump. Scolling it is under the intake pipe from the airbox. I'll have another look. I did think it was beside the DPF looking at the first image.
alpha omega Posted January 27 Posted January 27 it makes sense for it to be low down. on mine its at the bottom of the radiator
Pan Posted February 7 Author Posted February 7 (edited) On 1/27/2025 at 4:41 PM, alpha omega said: it makes sense for it to be low down. on mine its at the bottom of the radiator True yes.The clip audi suggest is very difficult to get off. You might get it with the proper tool?! The one on the downpipe came off handy enough and it is at the same level more or less. A big screwdriver(mini crow bar) levered against the metal bracket below will get it moving. I have documented the whole procedure of drain-flush- heater core swap-refill-bleed. Mostly in video from unfortunately 🙂 Will try piece it together and upload at some stage. If anyone has any questions about it give me a shout. Edited February 7 by Pan double pic 1
Pan Posted February 7 Author Posted February 7 Just to note a bit of H&S, when you do remove that hose, coolant will fire out of the downpipe. At your face if it's in around where the camera is above. 1
