Overlander Posted 6 hours ago Posted 6 hours ago I had a brake tube leak, its now been repaired. Most of the brake fluid had leaked out of the braking system. I refilled the brake fluid reservoir and in sequence starting from the wheel at the furthest pointfrom the reservoir tried to bleed the system. Ive tried to do this a few times, I get fluid at the nipples but the brake peddle remains completley spongey and the brakes are absolutley ineffective. I would be grateful for advice.
spartacus 68 Posted 3 hours ago Posted 3 hours ago I've got a Draper bleeder, but to be honest a two person approach (one pressing the brake) is better than vacuum system. Get plenty DOT 4 brake fluid, it's relatively inexpensive. Also make sure the silicone tube that you use from the bleed nipple to the used fluid reservoir is on tight. Top up the brake fluid reservoir regularly so as not to draw in more air. Use a proper brake nipple spanner, so there's no mucking about when closing off. You're right - start at the caliper furthest from brake fluid reservoir. Regardless if you're not seeing bubbles, press brakes around 15-20 times, then close off, move to next wheel and repeat. Double check brake hoses too. It they have been clamped for any reason they may have collapsed or deteriorated. Running the car will pressurise the system - so I would use that approach too.
