my Audi a6 C7 will not start at all I have had the battery changed and also the clutch switch/clutch master cylinder and still it won't start
my fault codes are
U111300 ABS/TCS/ESP CAN SIGNAL SIGNAL FAULTY
U111300 FUNCTION RESTRICTION DUE TO FAULT VALUE RECEIVED
can anyone please help me
THANK YOU
Does your diagnostic machine allow you to see all modules fitted to the car, looks like a Bosch so would think so but want to check.
are they all present
does it allow you to run a canbus network check
If your seeing all the usual modules the next thing I would do is as the fault codes look like there in your ABS module I would run live data on all 4 wheel speed sensors. See if all 4 are giving good feedback regarding speed reading.
  • 3 weeks later...
hi sid I booked in with Audi main dealer on the report Audi also said it was the clutch switch. Audi also said maybe the wiring wasn't done properly also fault code not deleted
so I have it booked in with Audi to work on it finger crossed that's the last of my problems
