GC79 Posted Monday at 08:07 PM Posted Monday at 08:07 PM Hi everyone. Since having the 2020 Audi E-Tron 50 for 6 months, the charging has been constant at 7kw from my home charger. In the past week the charging rate has dropped to 4.8kw and never goes any higher. I’ve tried a public 7kw charging point and does the same 4.8kw charging speed. It is due a service and going in a 2 weeks time, but not sure if the indicator warning message would automatically slow the charging speed. Has anyone had the same issue and if so how was it resolved?
cliffcoggin Posted Tuesday at 10:16 AM Posted Tuesday at 10:16 AM What was the state of charge when you began recent charging sessions? Are you aware that the charge rate will drop considerably as the SOC approaches 80%? It is usually said that it takes as long to charge from 10% to 80% as it does to charge from 80% to 100%.
GC79 Posted Tuesday at 10:54 AM Author Posted Tuesday at 10:54 AM I’ve had the battery percentage down to 20% and still not getting any higher than 4.8kw charging speed. Before it would do 7kw right up to a 80% and even between 80-100%.
cliffcoggin Posted Tuesday at 11:12 AM Posted Tuesday at 11:12 AM In that case I suspect a fault in the car.
Anton8 Posted 15 hours ago Posted 15 hours ago Cliff is quite correct in saying it takes as long to charge from 80% to 100% as it does to charge to 80%. Audi suggests that you don't charge beyond 80% though. Sounds to me it is a problem with the car also.
