Hi everyone.
Since having the 2020 Audi E-Tron 50 for 6 months, the charging has been constant at 7kw from my home charger. In the past week the charging rate has dropped to 4.8kw and never goes any higher. I’ve tried a public 7kw charging point and does the same 4.8kw charging speed. It is due a service and going in a 2 weeks time, but not sure if the indicator warning message would automatically slow the charging speed.
Has anyone had the same issue and if so how was it resolved?
What was the state of charge when you began recent charging sessions? Are you aware that the charge rate will drop considerably as the SOC approaches 80%? It is usually said that it takes as long to charge from 10% to 80% as it does to charge from 80% to 100%.
I’ve had the battery percentage down to 20% and still not getting any higher than 4.8kw charging speed. Before it would do 7kw right up to a 80% and even between 80-100%.
Cliff is quite correct in saying it takes as long to charge from 80% to 100% as it does to charge to 80%. Audi suggests that you don't charge beyond 80% though. Sounds to me it is a problem with the car also.
