Hi, I have recently bought a 12 plate Audi Q3, which I am delighted about, however, the sat nav doesn’t appear to work and I was hoping someone might be able to assist or point me in the right direction.
For context the car has the original Europa 2012 SD card installed. But when I go into the settings it says “0 Satellites found”. Having poured over previous threads on various forums I’ve come across 3 potential solutions.
1- The outdated maps need replacing with a more current version, thus fixing the issue.
2- The firmware is outdated, hence the Sat nav no longer working. For reference it has RMC_EU_P11474.
3- The GPS antenna has stopped working and needs replacing.
I’ve contacted the local Audi dealer and they believe it’s most likely a firmware/software issue, but haven’t told me if it’s something they can rectify. They’ve also quoted me £330 for the 2024 Europa SD card and installation.
Any help or guidance would be greatly appreciated! Thanks
I'd suspect the antenna personally. But an update to software is no bad thing.
I'd agree with Steve Q. Old software and maps should not affect the ability of the sat nav to detect satellites, even if it can use the satellite data.
