Hi what's a good number when looking at dpf saturation on the vcds
What number should we be concerned with. At moment there's no warning however not much motorway drives hence concerned
From memory and every car is different at around 40% you get a warning light on the dash, between 20-30% the car will regen on its own if all conditions are met, after a forced regen I’ve seen Them down to about 5-6%.
