Hi, I've searched the forums and I can't find the answer to where the rear parking buzzer is located (it seems the Convertible may have a different location for the rear parking buzzer / chime)
I've searched in the boot (offside as per other posts) and looked all round where the rear seatbelt is and its not there
The parking sensors were a factory option (I've had the car from new)
Any help would be really appreciated!
What problem do you have Matt to suspect the control module is at fault?
Hi there, the reverse parking sensor isn't working, the last time it worked the chime sounded quiet / not clear, and Ive used an ODBeleven which tells me its the buzzer that is at fault so I'm keen to replace it (and its only a cheap part - if i can find it that is!)
If anyone else needs this info, its nearside (passenger side) next to the speaker
