Trev1976 Posted 3 hours ago Posted 3 hours ago Has anyone had there injectors pop out on a 2.0tdi? I had it happen last wk,ve fitted new seals washers,bolts & clamp brackets & after 20miles the same 2 injectors have popped again,I’ve used genuine parts & used the correct torque settings which I got from a local engineer who has been building engines all his life. I’m hoping it’s happen to someone twice & that they found the solution ,both times the bolt sheared. Just done a scan & got these codes,don’t know if they are relevant to the issue. p0135 P1440 P0405 p2454 TIA
