Has anyone had there injectors pop out on a 2.0tdi?
I had it happen last wk,ve fitted new seals washers,bolts & clamp brackets & after 20miles the same 2 injectors have popped again,I’ve used genuine parts & used the correct torque settings which I got from a local engineer who has been building engines all his life.
I’m hoping it’s happen to someone twice & that they found the solution ,both times the bolt sheared.
Just done a scan & got these codes,don’t know if they are relevant to the issue.
p0135
P1440
P0405
p2454
TIA
P0135
p1440
p0405
p2454
TIA
Trevor.
I have merged your duplicate topics into one. Please don't create duplicates, it will not gain you any more attention.
