Vernaldo79 Posted 4 hours ago Posted 4 hours ago Hi folks. My 2013 A6 has been sitting for around six months and has a completely flat battery. Is there anyway to open the boot manually?
Magnet Posted 4 hours ago Posted 4 hours ago There’s usually a key hole ( very often partially concealed) that allows you to open the boot manually. Can you get into the car via. a key,,and if so I take it you can then open the bonnet? Kind regards, Gareth.
SimonM Posted 4 hours ago Posted 4 hours ago 10 minutes ago, Magnet said: There’s usually a key hole ( very often partially concealed) that allows you to open the boot manually. Can you get into the car via. a key,,and if so I take it you can then open the bonnet? Kind regards, Gareth. If the bonnet can be opened, you can attach a charger to the charging point !
SimonM Posted 4 hours ago Posted 4 hours ago If the bonnet can be opened, you can attach a charger to thecharging point ! Quote
