Vernaldo79 Posted February 7 Posted February 7 Hi folks. My 2013 A6 has been sitting for around six months and has a completely flat battery. Is there anyway to open the boot manually?
Magnet Posted February 7 Posted February 7 There’s usually a key hole ( very often partially concealed) that allows you to open the boot manually. Can you get into the car via. a key,,and if so I take it you can then open the bonnet? Kind regards, Gareth.
SimonM Posted February 7 Posted February 7 10 minutes ago, Magnet said: There’s usually a key hole ( very often partially concealed) that allows you to open the boot manually. Can you get into the car via. a key,,and if so I take it you can then open the bonnet? Kind regards, Gareth. If the bonnet can be opened, you can attach a charger to the charging point !
SimonM Posted February 7 Posted February 7 If the bonnet can be opened, you can attach a charger to thecharging point ! Quote
Vernaldo79 Posted February 8 Author Posted February 8 Charged the battery.......car still completely dead bar a few dash lights at the bottom.
Solution cliffcoggin Posted February 8 Solution Posted February 8 New battery needed. Don't forget to get it coded to the car.
Vernaldo79 Posted February 8 Author Posted February 8 3 minutes ago, cliffcoggin said: New battery needed. Don't forget to get it coded to the car. Yeah unfortunately so.
Vernaldo79 Posted February 9 Author Posted February 9 Walking past the car this morning and these lights are randomly lit. I'm guessing this is just because the battery has died a sorry death?
